Old 01-31-2009, 10:26 AM   #1
What kind of transmission do i have?
I own a 2003 ford e350 q4wd.
I am guessing that it is a 4r70w or a 4r100.
I would like to add some atf, and not sure if i should add the mercon or mercon v.
my guess is that it is a 4r100, which takes the regular mercon.
thx for your time and advice.
blair
blair is offline   Reply With Quote
Old 01-31-2009, 01:11 PM   #2
geoffff's Avatar
Re: What kind of transmission do i have?
There should be a "Vehicle Certification Label" stuck to your driver door with this information. (Starts with title, "MFD. BY FORD MOTOR CO", and has a barcode.)
At the bottom of the sticker, you have various info, such as axle ratio ("AXLE") and transmission ("TR"). Here are the transmission codes (as listed in my 2004 Ford E-Series manual, but I think they're the same in other models):
5 — 4R75W
B — 5R110
E — 4R100
U — 4R70W
2004 Ford, SMB 4x4, RB-50
Old 02-03-2009, 10:19 AM   #3
Geoff,
thx for the info.
I looked at the sticker you are talking about and found a 9 in the TR section.
What do you think?
Old 02-03-2009, 11:31 AM   #4
geoffff's Avatar
That's curious...
Luckily my public library gives me access to Chilton's online...
Code:
1997:
	E—automatic, E4OD
	U—automatic, 4-speed, 4R70W
1998, 1999:
	U—Four-speed automatic (AODE-W/4R70W)
	E—Automatic (4R100)
2000:
	E—Four-speed automatic with overdrive (4R100) with 4.2L and 4.6L engines
	U—Four-speed automatic with overdrive (4R70W)
	9—Four-speed automatic with overdrive (4R100), diesel engine
2001, 2002, 2003:
	9—Four-speed automatic (4R100), diesel only
	E—Four-speed automatic overdrive (E4OD/4R100), gas only
	U—Four-speed automatic overdrive (AODE/4R70W)
2004:
	5—Four-speed automatic overdrive (4R75W)
	B—Five-speed automatic overdrive (5R110/Hi-Torque), diesel
	E—Four-speed automatic overdrive (4R100)
	U—Four-speed automatic overdrive (4R70W)
2005:
	A—Four-speed automatic overdrive (4R70E)
	B—Four-speed automatic, TorqShift, (4R75E), diesel
	F—Four-speed automatic overdrive (4R75E)
	T—Five-speed automatic overdrive (5R110W)
Looks like you have the 4R100. Diesel, right?
-- Geoff
Old 02-19-2009, 06:09 AM   #5
Geoff,
Yep, that's the ticket.
Thanks for your time, and infinite wisdom.
Blair
