Old 04-24-2017, 09:29 PM   #1
Bbasso's Avatar
Question Wheel alignment first or tire rotation?
So my rwd E350 needs an alignment and tire rotation, which one should I do first to get the best results? I'm curious as to what the thought process is...
Thanks
Rob.
Current:
And had three other E350s...
Old 04-24-2017, 09:33 PM   #2
shenrie's Avatar
I'd do rotation and balance check first, then align. I'm rotating 5 now too.
Old 04-25-2017, 11:16 AM   #3
Bbasso's Avatar
Ok, thanks
Rob.
Current:
Old 04-26-2017, 01:17 PM   #4
I would rotate and then align as well. Might as well have the tire in the space it will inhabit for a while. More accurate if the tires are slightly worn.
Gtbensley is offline   Reply With Quote
Old 04-26-2017, 03:21 PM   #5
Glider's Avatar
I highly recommend road force balancing. The difference is very noticeable, especially on big, heavy tires.
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
