Old 02-08-2012, 08:02 PM   #21
Re: White Smoke From Tailpipe
Did they suggest running a additive? Of course Ford pushed their product on me when I had a similar problem that ended up as a failed injector. I've yet to have any turbo problems to date but feel it's coming down the road. So I'm sticking with their suggestion until I find info of something better. I like what Pat posted and may switch.
Old 02-08-2012, 08:10 PM   #22
Zeta's Avatar
Originally Posted by sdwindansea
Well, everything is fixed. It was a turbo bearing failure this time. Here are the notes from the service:
Removed exhaust down pipe, found oil present at turbo housing
Removed turbo per wsm, performed turbo bearing clearance check
Failed, out of specs, oil seals leaking
Removed and replaced chra assembly
Removed and replaced unison ring
Cleaned turbine housing vgt vanes
Reassembled turbo per wsm
Replaced hardware per wsm
Do you let the rig idle a bit after driving? Good idea especially if coming right off the highway. The turbo can still be spinning at 80,000 rpm if you just shut it off after driving at freeway speeds. With no oil pressure it can take a toll on the bearing. Also, the oil in the turbo gets superheated if the EGT is still high--I let mine cool to 400F before shutting down.
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 02-08-2012, 08:14 PM   #23
Dave, they did not recommend an additive, although I plan to start using one again. I seriously doubt an additive would have helped in my situation since I had the turbo replaced less than five months ago.
Zeta, yes I let van idle a bit after driving on freeways. I do not monito the EGT temp, not sure if scanguage 2 has this option. However I'd make sure the radiator and transmission temps are back to normal.
Old 02-09-2012, 10:33 AM   #24
With the Scanguage, I would just get an analogue Exhaust Gas Temp for $200 and tap the pipe that exits the exhaust manifold to the turbo. Place the temp probe there. Edge Insight or SCT both have digital monitors that replace the scanguage, with an optional back up camera.
Ketcham is offline   Reply With Quote
Old 02-13-2012, 01:48 PM   #25
That aint good geoff. Did they rebuild the turbo or put in a new one? Seems strange it only lasted a few months. I sure wouldn't be happy if they rebuilt it or stuck in an old one. Who did the work? I've had my share of engine trouble but knock on wood, no turbo problems at all with my 06 @ 70K.
