Old 06-06-2016, 09:57 PM   #1
4 point seat belts for the rear bench seat
We decided that the stock seat belts installed in the rear seat of our RB-50 layout were not safe for our two kids, age 7, and 9. Only one side had a shoulder strap, and it was pretty jenky. So we bought these 4 point seat belts to replace the right and left side of the stock belts.
4 Point Seat Belts - Push Button Buckle
These belts require you to drill one extra hole per seatbelt for the 3rd point (middle) of attachment. I ended up having to drill a total of 3 new holes. One for the 3rd hole on the right side, and two for the left side. The left side has a jenky shoulder strap belt and I wasn't able to reuse the anchor point due to it's positioning.
I ended up having to remove the bottom portion of the bench seat as access was prohibited from the back due to the way the water line was run for the shower (see pic). It would have gotten messy I think to try and cut the hole into a U shape allowing the partition to lift out and expose the anchor points for the seat belts. Although I still removed two screws from the partition to move it away from the seat belt anchor points to allow for drilling and installation.
These seat belts work out great. I'd rather there be a disconnect buckle from the third anchor to allow the belts to easily be pushed through to the bottom of the bed. Instead, I must loosen the belts, and slide them to the side when transforming into bed mode. Not a deal breaker, but theres a bunch of belts to deal with. But you can see from the picture that the seat does transform into the bed nicely still.
Also, we searched for a good solution for a head rest for the bench seat to help with whiplash in the event of a crash. This little back support and head rest works out great for our tall 9 year old.
Now wife is happy, and kids are safe!
2006 E350 Sportsmobile 6.0
https://phlite.net
phlite is offline   Reply With Quote
Old 06-13-2016, 12:14 AM   #2
Abitibi's Avatar
I've been thinking along those lines for my 65 Econoline. As is there's not seatbelts at all and my kids are the same age as yours. Lapbelts are easy enough to fit but my wife isn't as free spirited as I when it comes seatbelts... Thanks for the link!
Sent from my SGP511 using Tapatalk
2008 E350 Hambo
2001 E350 AmbuLand (sold)
1970 Econoline popup camper
1965 Econoline Travelwagon
Abitibi is offline   Reply With Quote
Old 06-13-2016, 03:55 AM   #3
I'm just curious if there's any concern no anti-submarine provisions are available with these belts?
I know traditional lap/shoulder belts we all run don't have that feature either but for true safety with younger ones the 5th attachment and retention belt would be a true safety improvement.
Sure they'd be a bit race-car like but so much more effective in a collision.
Not bashing these---just curious is all.
Old 06-13-2016, 04:05 PM   #4
tlg
tlg's Avatar
Installed two E-Z-On 86Y harnesses on our bench seat (visible in right of image). Loops sewn in at bottom of the harness accommodate the existing lap belt. Chest clip included. Single point of attachment in the rear. We've found they work well with a booster seat and on their own.
2014 Ford RB-50
Old 06-13-2016, 04:29 PM   #5
@tlg
Nice, thats great you can reuse the lap belts with that solution!
https://phlite.net
Old 03-28-2019, 06:44 PM   #6
Can I get more info on the headrest/backrest thing you are using? My search is coming up short.
Vanlifedream is offline   Reply With Quote
Old 03-29-2019, 11:53 AM   #7
This is it here:
https://therapeuticainc.com/spinal_back_support.html
https://phlite.net
Old 03-30-2019, 04:05 AM   #8
Thank you!!
Old 03-19-2020, 08:01 AM   #9
A bit off topic but what is the measurements of your bench seat? Anyone that wants to answer. I’m building a eb51 floor plan and need to cut and weld the bench frame I have to make room for the cabinets.
You can follow my build
Instagram @TheDirtVan
YouTube- TheDirtVan
https://www.youtube.com/channel/UCSePTshSLn79BOCGYwSwPbQ?view_as=subscriber
NoR32 is offline   Reply With Quote
Serenity
Makalu1
Priscilla
DocMP
