Originally Posted by Makalu1
We were smelling these whiffs ...with everything shut down, LP valves closed, and cold for days.
Assuming you mean the main valve at the tank. Seems unlikely that what you were smelling was coming from the main tank- probably some residual propane still out in the system. If you wanted to confirm this, you could close the main valve to stop any new propane going into the system. Then open everything (outdoors, in a safe manner) and release any remaining gas in the system past the tank. I would bet that you would not smell anything after that under the typical circumstances (cold temps, etc).
'08 E-150, std roof, wb, 2wd - basic cleanup done. Working on rough layout of 'furniture'.
Pretty much everyone will step on their 'willy' once in a while.
I usually make it a point to stop and put on my golf shoes first..
