Originally Posted by rean1mator
exactly how much of a delta is there between running it off ac vs dc?
If the use case is running an inverter to run the fridge on AC, let's assume that the inverter is 90% efficient and the fridge AC to DC converter is also 90% efficient. The total efficiency is .9X.9=.81 or 81% efficient, so you would be wasting almost 20% of your battery capacity as heat in the inverter and in the fridge power supply.
It's actually a bit more complex than this since a large inverter will waste more power than a smaller inverter if a smaller inverter can handle the load.
These efficiencies are total guesses but they may not be too far off........
