Old 10-25-2008, 07:54 PM   #11
I had a similar problem that spun SMBW. I suggested a check valve and after some research found the system did have one although they could not figure out why it didn't deplete the Starcool system also. You might call Leo at SMB. Ask about Boyer's van....Good luck.
Old 10-25-2008, 10:55 PM   #12
jlrray's Avatar
Send a message via ICQ to jlrray Send a message via AIM to jlrray Send a message via MSN to jlrray Send a message via Yahoo to jlrray
do you remember where the check valve was? Did replacing it fix the issue?
joe
jlrray is offline   Reply With Quote
Old 10-25-2008, 11:07 PM   #13
A/C
Joe,
It sounds like you definitely have a leak and lost your refrigerant. As mentioned, you will need to have the leak repaired and the system evacuated to remove any air that might be in the system.
The clicking noise you hear is the compressor clutch engaging and dis-engaging because the low-pressure switch is closing and opening relative to the compressor cycling off and on. When the pressure gets up to about 40psi, the low-pressure switch closes, allowing power to the compressor clutch. Once the compressor is operating, it quickly lowers the suction line pressure below the low-pressure switch setting of about 18psi, which opens the low-pressure switch contacts and removes power to the compressor clutch. With the clutch dis-engaged, the suction line pressure increase to start the cycle over again, and again, and again...
Any reputable A/C repair shop can fix the system, but as mentioned, let them know what you have and make sure the manual is available so they can see how simple the system really is. Chaffing of the hoses and aluminum fittings have caused too many leaks, inspect them regularly as items can shift over time/miles.
Good Luck!
John K.
John Kalmbach is offline   Reply With Quote
Old 10-25-2008, 11:48 PM   #14
joe
Sorry for the confusion. There was no problem with the check valve, only that it confused SMB to why all the coolant was not leaving the both systems. I never heard any clicking and don't actually know where the check valve is located. They just did not think it was a line leaking because 1/2 of the system was charged. In fact it stayed 1/2 charged (the starcool continued to work, just not to full potential) for well over 2 weeks...go figure??? Maybe that valve stayed closed. Just some info to tell your A/C guy.
