Old 10-24-2017, 12:03 PM   #1
Exclamation Airtronic D4 with 7 day timer
My Espar heater never has been right, I am the third owner and the person I purchased my SMB from told me the Espar had issues. I finally figured it out!
Problem: The heater would turn on and heat but would never shut off automatically as it should by the 7 day timer temp setting. It would run on low heat until I manually shut it down.
Fix: At the rear of the 7 day timer there is a connector that apparently was configured by the installer. There is a cabin temp sensor mounted beside the timer that should be connected to the brown with white stripe wire at pin 9 and to the gray wire going to the airtronic heater. My problem was that the gray wire was inserted into pin 1 of the connector. I cut the gray wire at pin 1 and that fixed the problem. Furnace now functions as it should!
2007 Sportsmobile FRB-50 4X4 Diesel, Aluminess front & rear, Espar D4 Airtronic, XL storage, leather, Kenwood GPS, electric Penthouse, Solar panels
2003 GMC Sierra 2500HD 4X4 Duramax Diesel
2006 Jeep Wrangler Rubicon LJ
tyonb is offline   Reply With Quote
Old 10-24-2017, 01:20 PM   #2
Flux's Avatar
Woot!!
Espar wiring diagrams and instructions leave much to be desired. Luckily I found a website where the guy had my exact controller and followed his directions.
Only issue is my temp sensor sits in a hot spot so I have to keep pumping up the temp. Easy fix though.
<br>
