Old 06-08-2017, 08:19 AM   #1
evy
evy's Avatar
Best water boiler option?
Hi everyone,
I don't have a lot of experience camping and I was wondering what was the best option for boiling water when boondocking.
For a cup of tea or cup of soup, if I'm boiling water to cook pasta (bigger amounts) I'll use the stove (LP gas).
-Using a standard 110v boiler off the inverter?
-Using the stove (LP gas) to boil 1 cup of water?
-Using one of those 12V cup boilers? (see picture below)
What is the best option for batteries or cost effective?
Thanks!
DIY conversion build, extended 2010 Ford 5.4L E250 + high top, from Montreal Canada, new to all this so please be patient and clear with me (never built or camped in a van yet)
evy is offline   Reply With Quote
Old 06-08-2017, 09:38 AM   #2
bemerritt's Avatar
i use a jetboil. doesnt get faster than that.
bemerritt is offline   Reply With Quote
Old 06-08-2017, 09:44 AM   #3
Jet boil is the best option. Super fast doesn't use very much gas.
Nrobert10 is offline   Reply With Quote
Old 06-08-2017, 10:07 AM   #4
1der's Avatar
Iwatani 15k btu single burner butane stove w a high efficiency camping pot. Stable, easy storage. Flexible / multi use.
Electric for water heating in a camper as primary water heating method is really not viable.
Beastie 3: 2002 7.3 EB Cargo: Agile TTB, CCV Mid Top, Custom Walk Through, Lots of stuff added. BlingMyRig.com
Old 06-08-2017, 10:09 AM   #5
evy
evy's Avatar
Do you guys use jetboil only for a cup of water or more? can you use it inside a closed camper?
Old 06-08-2017, 10:09 AM   #6
bemerritt's Avatar
Funny, this is the other stove I have, probably because you have posted it before. Ever have trouble wit hthe igniter failing? Just failed on me two weekends ago, basically fell apart. Other than that, between a large jetboil and that stove, I feel pretty covered.
Old 06-08-2017, 10:10 AM   #7
bemerritt's Avatar
They have many sizes. I use a bigger one so i can boil frozen, vacum sealed meals that I have prepared ahead of time. But i do boil smaller amounts for a french press.
My father uses a smaller one solely for tea. Id have no problem using it inside next to an open window
Old 06-08-2017, 12:47 PM   #8
Space is premium so something that can be used inside and out makes sense. I don't carry a Jetboil but it looks like a great system and probably works better in windy conditions than the typical butane stoves. Still I didn't want to pack small fuel canisters so I went with a portable 1 gal propane tank. I carried the little butane stove for a while to make coffee inside. Worked well but I finally installed an RV propane stove top...it was an expensive way to go compared to storing a small stove but now there aren't a hodgepodge of fuel canisters stashed in the van.
Old 06-08-2017, 07:41 PM   #9
evy
evy's Avatar
What's the difference between these Jetboil burners and a regular cooktop?
This is the cooktop I installed (suburban 6,500btu + 5,200btu burners)
Old 06-08-2017, 07:51 PM   #10
JetBoils (and similar models from places like MSR) are very efficient and boil water VERY quickly. The downside are they're made to work best with specially designed pots exclusive to that brand stove.
