Old 07-16-2019, 11:46 AM   #51
RandallDee's Avatar
Originally Posted by shenrie View Post
I picked up the blue septor 5g and installed the below spigot from amazon for 11 bucks. setup has worked perfect for us.
How are you attaching the spigot?
2023 Transit AWD w/ Van Haus build.
73 BMW 2002 O=00=O
RandallDee is offline   Reply With Quote
Old 07-16-2019, 02:29 PM   #52
shenrie's Avatar
I just drilled a hole and used the hardware included. heres a better pic. it comes with everything needed.
Old 07-16-2019, 02:44 PM   #53
RandallDee's Avatar
Gotcha. I thought you were attaching it to the threaded pouring hole on the filler cap.
73 BMW 2002 O=00=O
Old 08-05-2020, 05:25 PM   #54
Not original on my part, but I got a little tired of filling my Scepter MWC from my water tank, and then tipping the MWC to dispense water. I tried a spout with a valve, but that tended to drip. This pump does not pressurize the can, it essentially pulls up the water with each stroke.
The details and parts used are in the instructions on the link below.
Scepter Water Can Hand Pump Conversion | Danger Ranger Bear
Old 08-05-2020, 07:16 PM   #55
Twoxentrix's Avatar
More & more I appreciate gadgets & mods which are functional and alleviate the dependence of electric or battery power. I like this one Herb!
But, there is also something to be said for the "pressurized" mod for these scepters - had the opportunity to see the one 86Scotty put together a while back and it worked fabulously...impressive "spray" ability, and a simple install. I ended up going the WaterPORT route, based on what I saw from his.
Old 08-05-2020, 07:18 PM   #56
ConnieKat's Avatar
Herb,
Do you think that set-up would work on a 5 gal version of fold-up water bottle?
ConnieKat
ConnieKat is offline   Reply With Quote
