Get this:
https://www.amazon.com/Blue-Sea-Syst.../dp/B076GZQN98
After my power port hinge door broke off, I replaced the stock socket with this Blue Sea 1015 Socket. The Blue Sea unit has a higher charge voltage and is a bit deeper (which helps to keep my cb radio plug from falling out.) The Blue Sea rectangle cover pretty much covers the ugly rectangle void left behind.
I replaced the second power port below it with this Blue Sea Dual USB charger. It's trick.
https://www.amazon.com/Blue-Sea-Syst...ual%2Busb&th=1
