Old 04-23-2016, 09:57 PM   #1
Jsweezy's Avatar
Cigarette lighter socket removal...
How the hell do these things come out of here?! I've been trying to get it out without breaking it for the last 20 minutes...
Old 04-23-2016, 10:47 PM   #2
Great question.....I couldn't figure it out either.......it's been a while since I was behind the dash looking at those......
Old 04-23-2016, 11:24 PM   #3
Jsweezy's Avatar
Ya I have moved on until someone can help me out because I already chipped the one trying to get it out. It had the little slot like on the door panels for a screwdriver... Or so I thought. When the plastic snapped I knew that wasn't it ha ha.
Old 04-24-2016, 07:46 AM   #4
Depending on the year those are only removable from the backside of the trim panel. Since I don't see what you're working on makes giving helpful advice difficult.
Old 04-24-2016, 08:48 AM   #5
JackTuppVan's Avatar
They make a tool to remove the socket .
But I made something similar out of a piece of wire coat hanger that worked just fine.
You have a plastic retaining ring and a socket / sleeve.
The socket/sleeve has two holes /slots one on each side of the sleeve , the idea is to insert a tool into the socket sleeve hook into the holes and pull socket sleeve straight out leaving the plastic retainer in the dash.
Remove the lighter fuse before you begin.
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 04-24-2016, 09:11 AM   #6
Jsweezy's Avatar
JWA - Its a 2008 Ford E350
JackTuppVan - Thanks! I will give this a try and see what happens.
I appreciate the help guys!
Old 04-25-2016, 06:12 AM   #7
Jack's tool would be fantastic for this R&R---wonder where they can be found for sale?
Old 04-25-2016, 11:34 AM   #8
Don't know if it's one-size-fits-all or not, but here's a Dorman brand version on Amazon.
http://www.amazon.com/Dorman-56457-C...s=dorman+56457
Old 04-25-2016, 12:37 PM   #9
This is what i made from a piece of heavy gauge coat hanger wire.
It's made like a big safety pin.
Squeeze sides together, insert into the socket ,the tangs click into the sleeve holes , pull straight out.
You can use a screw driver as a grab handle.
NOTE: you only have to pull it out far enough to get hold of it with your hands.
Old 04-26-2016, 05:23 AM   #10
Great find Herb---thanks!
Now that's crafty Jack!
