Old 01-05-2014, 10:32 PM   #11
BrianW's Avatar
Re: City Water Fill Crack
"Black goo" is most likely butyl sealant. That's what mine has. You can get it at NAPA or most auto parts stores, although you might have to buy a whole roll of it. For just this small repair, hit up a local auto body shop and see if they will give you a little bit. (Although having a roll around is handy for lots of things...)
Old 01-06-2014, 09:47 AM   #12
I would guess it's just fatigue. The threaded portion gets the weight of the hose and is also being pulled on when being filled, eventually cracking. You could forestall it with a bit of thickened epoxy as a shoulder for the threads or add a support hook for the hose when you fill it so there is no pressure on the threaded portion. Or carry a spare and figure a break every 10 years on a small, cheap, plastic part is normal maintenance...
