Its time to replace my CCI Controls CO2 Mod. # 3400 CO2 detector. I'm under the impression that they are no longer available.
Have any of you found a replacement that fits the same hole?
Thanks,
Bob in Tucson where it is 79 today.
2003 Ford V10 Quigley RB50
I replaced mine a year or two ago and posted up the info on where to get it. It was the same unit. Try searching.
steve
Mine died yesterday as well, and it's way out of date. I did some searching on the web and found some similar but not the same one. I'll do a search here now I suppose.
Thanks Scalf,
I tried them before I posted and I may have to go with what they have. The face of their unit is about 1" higher and the back side which would be inserted in the wall is about .5" higher.
I'm just trying to avoid making the existing whole any larger, which really means trying to avoid doing any work.
I couldn't find any the exact same size but did find one slightly larger (Safe-T-Alert) and enlarged the hole slightly so that it would fit. That worked...
Jack
'01 Ford EB50p Quigley 4WD
