Old 12-07-2023, 07:44 PM   #1
Cutting into Barn door pillar?
Hey Folks, Im to the point of my build where I'm ready to install a light switch. I'm keeping my factory headliner and the interior plastic pieces that cover the pillars and I would like to mount my overhead light switch on the rear pillar of the barn doors. I have a 12v dimmer switch that is similar to a 1 gang single light switch box that basically needs to be installed in a square cutout like a house light switch. My question is has anyone cut and drilled into the pillar? ...and if so what tool would be best for cutting a 2"x3" square hole for the gang box?
stevigee is offline   Reply With Quote
Old 12-07-2023, 08:42 PM   #2
FYI - that pillar is structural and designated as a no-cut zone, as far as the BEMM specifies in order to maintain roof crush strength for rollovers.
That said… if that’s not a concern for you, and it being a body-on-frame vehicle… the van won’t far apart. If I wanted to cut a holt like that, I would drill out the corners with a regular drill bit, then cut in between with a cutoff wheel. This will avoid any sharp notches that could cause later cracking.
Old 12-07-2023, 09:55 PM   #3
dhally's Avatar
A jigsaw with metal blade would probably work too. Grinder is easier, you need one!!
2009 E250 RB 5.4L "SilVan"
Old 12-08-2023, 08:43 AM   #4
BrianW's Avatar
I cut a similar hole in my 2011 at that spot to make an access hole to install hardware for a third-seat seatbelt. I drilled corner holes and then used a multi-tool (VERY carefully). Don't know why I didn't think of using my grinder :-(
Old 12-08-2023, 09:01 AM   #5
If you’re gonna use a grinder and cut off wheel, cover the glass the something. Hot metal sparks will ruin the windows.
Nrobert10 is offline   Reply With Quote
Old 12-08-2023, 09:21 AM   #6
gahamby's Avatar
Can you post a pic of the device you want to install?
'07 GMC 2500 6.0
Old 12-08-2023, 04:24 PM   #7
This is the switch and lights. I have 8 lights and was thinking 2 zones, front 1/2 and back 1/2. But after looking at the pillar I dont think it will work I think the pillar is not deep enough and maybe risky cutting into. Im now thinking a surface mount box may be the way to go but its not as clean. There is another 12v -round switch on Amazon but not sure.
Old 12-08-2023, 05:58 PM   #8
Will this type of 12v dimmer from Amazon work? will it work as a all in one on/off switch plus dimmer or will I need to connect a separate on/off switch plus this dimmer? Can I install 1 for front 4 lights and 1 for for rear 4 lights? Its small enough where I might be able to get away with just drilling a hole or two.
Old 12-08-2023, 06:50 PM   #9
I agree. There are better options than using a residential style box/switch setup. I use them sometimes but in wooden cabinetry. For your plan I'd go with Stevigee's advice, or betteryet get the inline remote style and use an app from your phone. I actually prefer both.
Old 12-08-2023, 06:58 PM   #10
The Amazon dimmer looks like a simple potentiometer.....need more info on the original one.
Assuming the lights are LEDs yes the pot should work.....you could install two pots, one for each zone. I would buy the Amazon pot and try it with the lamps before cutting anything. It may behave strange...or not.....
If you want on/off functionality and dimmer control you can find pots that have on/off capability as well. Ebay, Digi-Key or Mouser easy enough.
Can you provide a link to the Amazon potentiometer?
The on/off potentiometers have the on/off "click" at the beginning of the rotation...or you could wire in a separate on/off switch. That's how my ceiling lights work.
