Hey guys.
this is my version of a table/bed for my DIY campervan.
you'll need :
1-2"x4"x96" (be picky, least knots)
1-2"x6"x24"
6-spring hinges
1-latch/lock
4-adjustable table legs levelers
cost me around 30$ (excluding top)
the top and sides will have the same laminate as my counter tops and refrigerator face panel. I will add another plywood on top and cut the corners 1"diam. The top width is 22" I have 24.5" between my two bench and 47" inches in length because the laminate sheet is 48" you need at least 0.5" on each sides to cut it with a router.
If you noticed I used a piece of 2"x6" on one side, simply because I did this project using pieces I had laying around (scrap).
Also when I use framing wood to make furniture I like to take off 1/8"-1/4" on each side of the 2"x4" using the table saw, I just break the corners using sand paper by hand real quick, IMO it looks better.
If you want to see it in action :
https://youtu.be/KodMjc-DyQ8
