Reelchef: How wide is the T-molding that you ordered? If it's the typical 3/4" or 13/16" wide stuff, your 5/8" BB ply may be a little skinny.
Are you planning on using contact cement or PVA glue and an iron?
...you'll also need a router and trimmer bit.....
Hi boy wonder .
I've ordered 40 ft ?. And 20 feet of 1/2 inch t molding.
I already have a edge trimmer for the laminate a slot 1/16 cutter coming for the t slot of the molding.
I'll be using contact cement for the laminate install.
I do the occasional bit wood working( field target rifle stock,grips and furniture) and machining as a hobby so I've got lots of power tools
Here's some rough sketches I've been working on.
