What did you line the inside of the door with? Carpet?
It is carpeted , but it came that way. Im pretty sure there was table option available but not installed.
On my other door there used to be a flip up table but the previous owner switched it to al "towel rack" I dont know why ...
2002 E250 5.4 4R70W 2wd 3.5 inch lift Pleasure-Way Traverse on 16x8 with 265/75/16's
Got most of the pieces cut yesterday morning.
Then I went mountain biking and wiped out on a DH section here on the north shore vancouver BC. Spent the rest of the day in hospital , concussion , wrist sprained and almost knocked out teeth , and stitches ...
Tried to split a rock with my face
I managed to get it drilled and temporarily screwed together today. Next will be drilling dowel holes in it while it's together..
After that I will using the router to cut slots for t molding everywhere it goes.
All the exterior pcs will have melamine laminate applied
