Old 12-02-2013, 10:30 PM   #1
Kzinti2's Avatar
Expanded Canine Navigator Perch
As navigator, Lucky has sniffed out many-a road, but grumbled at the gaping void in front of his chosen perch. Something needed to be done! A bigger platform was in order and, due to the odd shape, a template was needed. Lucky supervises while the cardboard is roughly fit:
The colored strip was used as a scribe strip against the various short angles
Here's the resulting piece cut from a square of OSB. Here, the colored strip is laid along the back line traced in the van so the front line can be traced on the wood
Resulting wood platform in the van
While it fits well, with a couple inches foam, it's going to be really high. Hmmm... Plan B maybe in order. After more templating and cutting, we have this
With a milk crate base and a couple inches of foam, this will be about the same height as the front edge of the seat.
2004 SMB w/Penthouse - Ford 2wd RB 6.0 - new to us in 2011
Kzinti2 is offline   Reply With Quote
Old 12-02-2013, 11:29 PM   #2
Kzinti2's Avatar
Re: Expanded Canine Navigator Perch
While the wood would support him just fine, Lucky demands comfort. Here the foam has been cut to the shape of the wood. The foam needs to be on top when we're done to avoid complaints
The 2" green foam and marine-grade vinyl fabric came from Jo-ann Fabric
http://www.joann.com/heavy-duty-foam-sl ... am&start=5
http://www.joann.com/marine-rv-vinyl-/prd23669.html
Here the pattern is drawn on the back of the fabric. Start by tracing around the wood with its up-side down, then measure down 3.5" for the sides (2" foam, .5" wood, 1" staple space); allow 1/2" for sewing seams. The book was used to draw corners
The fabric cut out. The strip is needed for the sides at the inside corner. The wood is upside-down here like the fabric
The fabric is now sewn into shape and the foam is inserted. The wood is upside-up. The metal bit in its lower left corner is a 1/4"x20 T-nut for a future support leg
The wood is now inserted. The leg-side of the T-nut is visible in its hole in the right corner
Cover is stapled to the wood. The leg is shown detached. It uses a hanger bolt (1/4" lag on one end, 1/4"x20 tpi on the other) to attach to the T-nut
The leg is attached. The main area is supported by the crate. The leg prevents tipping when this corner is stepped on
Finished top side
Old 12-02-2013, 11:36 PM   #3
Awesome post. I like how you detailed the upholstery pattern.
Tell Lucky he has the best owner a dog could have, if he doesn't realize it already.
Old 12-03-2013, 09:33 AM   #4
No clue why that is necessary, he looks just fine in the driver's seat.
Old 12-03-2013, 12:10 PM   #5
Tapatio's Avatar
I also have a custom canine perch. Unfortunately it's very expensive and high maintenance.
Callsign KK6GIY
Old 12-05-2013, 01:07 AM   #6
Where is the pic of Lucky on perch? . Don 't tell us he didn 't like it.
stanw909 is offline   Reply With Quote
Lola
Eddie Haskell
MoMo
skyrat
