Re: Flate Plate Circulation Pump Leak
Boy, fixing this leak is a tough one. Peter @ SMB wasn't much help. He stated they don't use the coolant pump anymore, I'm guessing but I think they use the Espar flat plate set up. He said they used to get them from Port Supply, but looks like they don't have them anymore. I'm just trying to gain access to the pump and find a manufacturer's number or possibly clean up the seals.
Trying to get the metal housing that holds the pump on is a problem. I'm pretty sure they have nuts inside the body of the van that the bolts are screwed into and not sheet metal screws. I'm having a heck of a time trying to figure out how to gain access to those nuts. Just to the rear of the pump is a drain with some of the floor material screwed on and underneath that is what looks like foam insulation. Possibly if you scrapped all this out you could get your arm back in there with a wrench and get hold of the nuts.
Just checking to see if anyone else had removed their circulation pump and just how they got the metal housing off that supports the pump?
