Cabinet is in and looks great. Still waiting for the towel rack to come in but looking forward to using it.
You still need to be careful opening and closing the side shelves. The springs are very strong and if you slip opening a side shelf you will get your fingers caught when it closes. Closing can be just a tricky. Not sure how Derek is closing the shelf in his video as my hinge system does not look the same. Maybe it is. I'll try posting a quick video of it sometime.
There was no installation instructions with the unit and even using the template that was provided was not clear with how the holes should be drilled.
I am sure we will be modifying the unit after a few weeks of use and I'll make a post of the results.
Again the actual construction looks great minus the above mentioned items and I am sure I will get many years use out of it.
