Re: gray water tank vent done broke
Robb,
Cut the broken tee off with a saw just above the glue joint, then cut down through the outer portion of the tee in several places. Use a small wood chisel to chip away the pieces. A heat gun will help with this. I have had to do this many times with ABS pipe like you have - not much of a problem.
AgileOffRoad.com
