Old 07-29-2015, 09:06 PM   #1
brig's Avatar
Help! 2010 RB50 Marine Vinyl Floor Repair
So, I was moving a copier for my wife's job…..and it seems to have sustained a minor injury.
There was a sharp corner on the copier that dug into the vinyl, unfortunately ripping it. The piece is still intact and actually looks ok but obviously it needs a permanent repair. It's about 2" x 2" piece.
So, I'm looking for suggestions. Thinking adhesive to glue the piece back down would suffice. We have a rug as well that we normally use but unfortunately it wasn't in the van at the time.
Ideas?
Thanks all!
2010 RB50 4x4
"Gnar-V"
brig is offline   Reply With Quote
Old 07-29-2015, 09:26 PM   #2
Viva's Avatar
Re: Help! 2010 RB50 Marine Vinyl Floor Repair
Not that I wouldn't read all tips here - as many may have "been there; done that," but you might try contacting Nautolex to see if they have a recommended procedure/glue/etc. Presuming the flooring is made by Nautolex (for some reason I feel like it is, but not sure).
Old 07-29-2015, 09:50 PM   #3
brig's Avatar
Thanks for that. I couldn't find the actual floor supplier via SMB.. I'll check into it.
2010 RB50 4x4
"Gnar-V"
Old 07-30-2015, 08:04 AM   #4
So that's what it's called? The stuff that comes in SMBs? I've always wondered. I wonder how expensive it is, or how hard to work with?
Thanks Viva
Old 07-30-2015, 08:36 AM   #5
Thanks Viva
Eric: The "decko-dot" sample that I sent you is also made by Nautilex.....although I had no idea that the newer SMB stuff was also the same brand...
Old 07-30-2015, 05:14 PM   #6
Thanks, I didn't know that either. I really like that sample and also what you've done with it. I think it would work better for upholstery than flooring for me. I've always really like the newer SMB flooring (Nautilex, i guess) but until now I didn't know what it was.
Old 07-30-2015, 05:58 PM   #7
me too....now that I've got it in both places and lived with it a while.
Old 07-30-2015, 10:58 PM   #8
Viva's Avatar
Well, like I said, I'm not sure. But for some reason in the back of my mind I thought the "marine vinyl" flooring was made by Nautolex. But I could be wrong. It reminds me of flooring that you often see on pontoon boats or certain runabouts.
I think the "coin" is Loncoin by Lonseal, but it's possible people just call it that sort of like saying "Kleenex" instead of facial tissue.
Old 08-07-2015, 06:30 PM   #9
brig's Avatar
Any actual experience with my original post question would be appreciated.
2010 RB50 4x4
"Gnar-V"
Old 08-07-2015, 08:14 PM   #10
JackTuppVan's Avatar
First clean the area to be repaired, the vinyl and the sub-floor . Warm the damaged area with a hair dryer to "soften" the vinyl . apply a small amount of vinyl floor adhesive to both the sub-floor and the vinyl. press into place , squeeze out any excess glue .wipe up any excess glue .make sure patched area is aligned correctly,then place a weight on the area until glue sets up .
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
97 Eco
MTDave
Jiminy
Gooseberry
