Old 03-25-2018, 07:51 PM   #1
pjpvi's Avatar
Help me find this valve
Can't find this valve on-line anywhere. Can anyone point me to it? It is leaking as you can see and wanted to be lazy and hopefully just unscrew the valve part and replace from new. Thought it would be easy to find the valve, but not able to find so far.
1/2" PEX - 1/2" PEX
Original fresh water drain valve from 2005 SMB build.
Thanks!
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 03-25-2018, 08:01 PM   #2
Maybe one of these?
Drain Petcocks (TCD 60-0320P) | TCD Parts
BroncoHauler is online now   Reply With Quote
Old 03-25-2018, 08:23 PM   #3
pjpvi's Avatar
Thanks Herb. Didn't realize the magic search word was "petcock". That helps.
Phil
Old 03-25-2018, 08:36 PM   #4
Bellpilot's Avatar
Usually you can just give a twist on the jamb nut and stop the leak.
2010 E350 6.0 4x4 EB 50 SMB
2012 E350 V10 4x4 RB 50 SMB (sold)
2007 E350 6.0 4x4 RB 50 SMB (sold)
Old 03-25-2018, 08:59 PM   #5
Fitz's Avatar
Why not just re-pack it?
KN6BJX
Old 03-25-2018, 09:04 PM   #6
pjpvi's Avatar
Good suggestion and question. I am a petcock virgin (leave it!). Will take it apart once it finishes draining and check it out.
Thanks
Phil
Old 03-25-2018, 10:43 PM   #7
Fitz's Avatar
Graphite or Teflon, pull the nut off, add a wrap to the stem, cinch the nut down and you should be good.
KN6BJX
Old 03-26-2018, 12:44 AM   #8
Bellpilot's Avatar
Agree with Fitz
Old 03-26-2018, 09:21 AM   #9
Thanks
OMG---you can NOT leave low hanging fruit like that and expect us to just leave it alone?????
A lot of items these days are easily found online if only we know their proper names or how they're typically classified. I've struggled for days then suddenly found it, most often doing a simple Google search but looking at the images.
JWA is online now   Reply With Quote
Old 03-26-2018, 11:09 AM   #10
It might just need a good cleaning, then some new packing and snugging down the packing nut will probably work. Check the shaft for corrosion though, if it's badly pitted it might need to be replaced.
Van22
Van22
Turtle
rafeman
