Old 12-28-2015, 11:59 AM   #1
mbachani's Avatar
House water pump
Got stuck, still in the recent snow storm in New Mexico. Water pump froze during the night.Got it thawed out and worked fine.Next night froze again.Tried same thawing techniques, no luck.Changed fuse, no luck.Ideas please?
Bob from Tucson
Bob
mbachani is offline   Reply With Quote
Old 12-28-2015, 02:43 PM   #2
It's a simple 12v appliance, just switched. Coming off the water pump you should see a red 12v wire and a black ground. I would try wiring it directly from a power source, perhaps the fuse panel which may be close by depending on your floor plan. If it doesn't come on and the fuse is good then the pump is toast. Not that big of a deal though, around $50 for most of them. It's a standard RV part you don't necessarily need to get from SMB, you can get a capable water pump from any RV sales/service/parts center. Make sure it's above freezing when you try it!
good luck
Old 12-29-2015, 08:55 AM   #3
Bbasso's Avatar
Northern tools and harbor freight also carry water pumps...
Keep in mind when shopping for a replacement, the psi and gph. Do you like what you have in regards to water pressure? You can change it to your liking.
Rob.
Current:
And had three other E350s...
Old 12-29-2015, 09:04 AM   #4
Gooseberry's Avatar
Check your ground wire on the pump. Moving the pump might have worked it loose.
Sent from my iPad using Tapatalk
Old 12-29-2015, 08:40 PM   #5
mbachani's Avatar
Thanks guys, after bouncing around on some snow covered , mud rutted rds. it started working. So I'll take a closer look when we get home.
Thanks again!
Bob in Tucson
Bob
Old 12-29-2015, 09:16 PM   #6
It's almost certainly a bad ground then. Have fun!
2006 Ford E350
unreng
Dodge
lugee
