Old 01-05-2015, 06:38 PM   #11
Re: Interior advice needed and take a look at what I am doin
Originally Posted by E350
Wheelie: If I understand you right, you did not install the 3/4" cdx plywood. Got you. I just suggested using a hardwood plywood. In fact, I have used a seven ply 1/2" maple hardwood which really impressed me as to strength to weight ratio.
Agreed,
I have a friend who may have a few honeycomb core panels with a few dent/scratch. and they will be free.
He also has the thin alloy honeycomb structural panels.....load bearing, light and extremely strong.
(but will see if he delivers.)
I have lots of room under, I hate weight. I am going to raid my wood boat restoring friends shop for some hardwood ply.
as a matter of fact, I may start replacing the original boat anchor cabinets slowly.
I removed a rear shower base, rear sink, drain plumbing, holding tank & cabinetry and shed 380lb of worthless & unusable
cabinets.
I bet there are 60lb of overused brackets in an SMB.
11 Tiger Bengal Chev 3500HD 4WD Diesel (Current)
05,06,08 Tiger CX Chev 3500 & Ford F350 (SOLD)
91,94,95,97 Tiger GT,CX Chev & Dodge (SOLD)
3-SMB's E250's, E350's - (SOLD)
Wheelie is offline   Reply With Quote
Old 01-05-2015, 07:30 PM   #12
E350's Avatar
Personally, I am a cabinet minimalist for both space and weight reasons (I get all the space I need in from the fixed top, but that weighs a ton too). So I get where you are coming from.
Old 01-05-2015, 09:13 PM   #13
I use baltic birch........3/4" is 11 ply. It's a bit heavy though. My local supplier also sells a Chinese import birch with lots of ply's and it's significantly lighter than the BB, so I've been using a mix of 3/4" import, 3/4" BB and 1/2" BB. The BB is actually metric: 18mm and 13mm.
I have never worked with the honeycomb stuff, but it looks like it could be a PITA to work with. They sell that at my local metal supplier, but it ain't cheap..
