Originally Posted by rltilley
This will get me away from the disposable propane bottles.
U-Haul is in the process of rolling out refillable 1-lb propane cylinders to their stores. They are currently available in a few stores in CA; should be available in the remainder of the country by the end of the summer.
The cylinder itself is a re-branded Flame King unit, YSN164.
Using a larger LP tank, or refilling the 1-lb cylinders yourself from a larger tank will probably be less expensive than getting refills at U-Haul, but getting refills at U-Haul will be less expensive and less wasteful than buying disposable 1-lb cylinders.
YMMV
