Los Angeles area replacement water pump source
My water pump is showing lots of corrosion at the gasket between the motor and the water handling parts. It was working fine last weekend but when I went to fill a dog bowl with water this afternoon, there was no pump. Inspection revealed a blown fuse and when replaced, the new one blew as soon as I flipped the switch. Given the state of the pump, I assume I'm just in need of a replacement. Can anyone recommend a source in the LA area (preferably near to Pasadena)?
1994 5.4l E250 sportsmobile van, 2WD w/ 4" lift and larger tires.
