Old 11-05-2016, 08:22 PM   #1
Modifying a 110 fridge to run efficiently on an inverter
I found this article interesting. He has used a few relays to make a dorm type fridge turn the inverter in his van off and on so that the inverter runs only when needed. Making the fridge run on about 30ah over 24 hours. I am considering this in my build. Any thoughts?
"The problem with common sense is, its not that common." Mark Twain
1999 F-250SD XCab 4x4 5.4 170k
1998 E-350 LWB (Being converted now)
www.DirkMitchell.com
Dirk Mitchell is offline   Reply With Quote
Old 11-05-2016, 09:30 PM   #2
larrie's Avatar
Take a look at this thread, http://www.sportsmobileforum.com/for...tor-15187.html.
Len reduced the power draw by adding insulation on the outside of the fridge.
Larrie
Old 11-05-2016, 10:35 PM   #3
Thanks that is a great link! After looking through it a combination of the two could make an amazing setup, the one he has is pretty impressive on its own.
TBD
thatsandrea
Behemoth
Besags
