Old 06-20-2017, 02:28 PM   #1
Norcold AC/DC refridgerator not working
Hey gang. Hoping to find someone who might have some insight to the problem and some troubleshooting guidance. I have Norcold AC/DC refrigerator and the DC side no longer turns on. Let me qualify that statement... The "light" comes on, but the compressor doesn't run. The AC side works fine. The fuse is good and the 12V battery is brand new. Any thoughts I should check next?
ddiggler is offline   Reply With Quote
Old 06-20-2017, 02:41 PM   #2
Most of these use a combination AC/DC and DC/DC power supply, to convert the incoming power to what the compressor and fan use - in my limited experience about 24VDC. It sounds like the AC/DC side is working but the DC/DC side may not be. If you know how to use a volt meter you can check the power supply and see what output it makes on 120VAC and what it makes on 12VDC.
Wowbagger is offline   Reply With Quote
Old 06-22-2017, 11:27 AM   #3
Here is a Norcold service manual courtesy of Bryant Rv
http://bryantrv.com/docs2/docs/misc/...42A_080807.pdf
it has a troubleshooting flow chart.
Old 06-28-2017, 01:13 PM   #4
Thanks Greg!
Old 07-04-2017, 10:40 AM   #5
Link to parts...
My refridgerator is pretty old. Norcold Model DE-351 AC/DC. I pulled it out and the power supply assembly is all one unit. I was able to find parts at the following...
You are being redirected...
I'll report back if this solves my problem. I hope this may help others.
-Dirk
