Hey guys, been under the rig... cant find where the Norcold drain tube has been put through the floor? Please tell me SMB didn't just cut and plug this on the fridge? Is it maybe tapped into our grey tank?
I searched but couldn't find anything on the drain line.
FYI: Talking about the freezer water drain tube thats located on the drip pan under the ice maker on the larger Norcold 12v/110. I can take a photo if need be.
Read this on another board... say it's not true
"The drain tube on the back of the refer goes into a small plastic cup that collects the water and then it evaporates. Norcold says to fill the cup with water above the bottom of the drain tube so that it's submerged. "
