Old 06-24-2019, 11:52 AM   #21
Originally Posted by gahamby View Post
Are you familiar with how to use a digital volt meter?
If not, try watching this.
Old 06-24-2019, 01:38 PM   #22
I think so...but I'm open to a lesson
HIGHCOUNTRYMIKE is offline   Reply With Quote
Old 06-24-2019, 11:00 PM   #23
Otter's Avatar
Originally Posted by arctictraveller View Post
If not, try watching this....
Hey, that was great. Thanks for posting.
Old 06-25-2019, 07:12 PM   #24
OK
Much better understanding of the meter and current in general.
Thank you.
Old 07-23-2019, 07:24 AM   #25
Just to followup, I did order a new thermostat/control switch assembly and installed it the other day. The unit now seems to work on all the different cold settings. Hopefully, I will get at least a few years of service out of the thing. Fingers crossed. Thanks for all of the input and discussion.
2017 sprinter 4x4 rb 150 penthouse top
Ragnar is offline   Reply With Quote
Old 07-24-2019, 10:59 AM   #26
Ragnar,
did you replace the thermostat/control on SMB installed Norcold?
my on/off switch is almost impossible to turn on/off.........
what were your problems with your ?
I'm off to NV, CO and Utah as we speak.......hope mine works on this trip.
Old 07-24-2019, 11:16 AM   #27
geoffff's Avatar
Originally Posted by LenS View Post
Should have a two year warranty I think. AC/DC not absorption. Power hog....3.6a*12.5v*24hrs = 1000 watts per day
Yes, but the compressor won't be running continuously, right? If it's running 33% of the time, you have:
(33%)*3.6a*12.5v*24hrs = 350 watt-hours per day.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 07-28-2019, 11:36 AM   #28
Originally Posted by HIGHCOUNTRYMIKE View Post
Ragnar,
Yes I replaced the thermostat and control switch. It comes as a single unit and cost about 25 dollars including shipping. I have the unit on setting 3 and it has been running about a week turning on and off. On setting 3 it runs about 25 percent of the time which is about what the unit did when new. About 36 to 38 degrees F on that setting with outside temps 70 to 80 F and van interior substantially warmer. The only difficulty was the install location in the rear upper corner requiring my arms to be about 6 inches longer than I have. The sensor part has a coating on it but the "brain" is a little metal box that does not appear sealed. Due to the interior location moisture will always be getting in there and causing rust and degradation. Just bad design is all. I ordered two more and put them in the repair kit.
