Originally Posted by DesertDan
By anyone?
Plans for do it yourself builder with paper templates etc. It would save lots of time.
I had the same thought when I started building mine! I did make and save some templates. The technical problem with sidewall templates is that the curvature of the sidewalls varies from a centerline on the vertical axis. Therefore, if you are building with a set galley width, for example, each part along sidewall would vary from front to rear. I guess you could make one average template to use and then add some kind of filler pieces, but I didn't want that. I'll try to upload some pics of a really handy/removable galley door cabinet that I built. The bottom now holds a paper towel dispenser, and the photo was taken before my door catches were installed. Top and doors can be folded open with cargo door opened or closed. Might give you some ideas. Cheers!
