If you don't count forgetting to turn on the gas, I have never used that procedure in 4 years. But now that you pointed it out, I see it clearly stated in the manual. I would suspect that you would only really need to perform that after the first usage in awhile, but then why couldn't you have a leak in between thermal cycles. I would have preferred them to just lengthen their time from the blower starting until and an actual ignition. More to ponder, thanks for the info.
