Was camping over the weekend and my pump in the evening started cycling on n off at increasing frequency. I looked at the pump and it was leaking where this assembly attaches to the lower housing. it leaks only on the outlet side. Is it a bad seal or better to replace the pump altogether?
Unfortunately it is where the seam is created when you attach that unit I pictured above to the rest of the unit. The outflow connection is sealed fine.
