03-19-2019, 12:35 PM
Propane tank: How to empty?
Originally Posted by 86Scotty
Brian, I sandblasted and painted mine without even emptying it. I emptied it later to change a valve.
Wow, really? You’re braver than I. Anyway, I need to take it somewhere to have it done and I’m sure they wouldn’t touch it full.
03-19-2019, 01:14 PM
Originally Posted by SteelheadJones
I bought a used Westy tank a couple months ago. Assuming I empty it can I grind/cut the existing mounts off and weld new ones on? Or am I just asking to blow s*&@ up?
It's never recomended to weld on any pressure vessel. At a minimum, if you do, I'd have it hydrostaticly tested prior to purging and refilling.
03-20-2019, 01:08 AM
What type of company does hydrostatic testing?
2003 Astro AWD
2005 Tacoma Access cab 4x4
03-20-2019, 09:47 AM
Check with your local dive shop or fire extinguisher supplier.
Or your local supplier of propane and propane accessories.
'07 GMC 2500 6.0
03-20-2019, 10:41 AM
Agreed, I use to have scuba tanks hydro'd at the dive shop until I found out they sent them to the local fire extinguisher shop. It was faster and cheaper to take them there in the first place.
03-20-2019, 10:44 AM
Thanks guys, much appreciated.
2003 Astro AWD
03-20-2019, 12:44 PM
https://www.ebay.com/gds/How-to-Tran...5245456/g.html
try this, apparently once you have transferred all the propane you need to fill the empty with an inert gas/air.
'07 GMC 2500 6.0
03-20-2019, 01:21 PM
Thanks. Missed that it my research (a how-to on EBay: who knew?). Sounds like more than I want to mess with, so unless I can find a local dealer that is able to do it for me, I guess I’ll just be cooking all my meals for a week in the van to use up the propane :-)
03-20-2019, 03:33 PM
Could be worse. Work on some new recipes.
'07 GMC 2500 6.0
03-24-2019, 12:34 PM
#20
Propane is non-toxic and I've always just vented it to atmosphere on the rare occasions that I've needed to empty a tank to remove it from the vehicle. It's really not practical to empty a tank and recapture the propane, since it needs to be stored as a liquid and comes out of the tank as a gas.
Remember that propane is heavier than air, so it runs downhill - it can pool in the bottom of a bucket, inside a sewer, etc.
When it comes time to refill the tank you need to tell the attendant that the tank has been open to the air so they can purge it before filling.
