Re: Refrigerator Cabinet Cooling Fan
I have a small thermostat at the rear of the fridge. This swich on/off the circuit of two fans.
One small (60mm diameter) at the heat exchanger of the fridge and one bigger (120mm diameter) i built in the wall between fridge and gaucho. He blows the air behind the gaucho. The thermostat opens at about 100F. The fanīs just work after turn the fridge on inside with the internal switch. In case it is off -for longer no use periode- the fanīs will not work also if the fridge is connected to the batterie
I took an old speaker bezel on the outside.
www.Dieda-unterwegs.net
