Old 05-28-2014, 07:34 AM   #1
Quercus's Avatar
Removing Old-School Dinette Column?
Our New/Old 89 Ford with its 1993 SMB conversion has a dinette that doesn't seem to want to come out. I'm afraid to force anything, and wanted to know if there is a trick to it -- there seem to be three or four tabs on the plate to which the cylindrical column attaches, but they don't seem to be movable.
Any vintage SMB owners know the trick?
Otherwise, I'm going to have to take off the whole mounting plate and figure out if it's rusted on or something.
Quercus is offline   Reply With Quote
Old 05-28-2014, 07:47 AM   #2
Re: Removing Old-School Dinette Column?
spray some WD-40 or PB blaster in it. There is no trick that I know of. Has it been in there awhile?
Currently vanless. Weird.
Old 05-28-2014, 11:03 AM   #3
Quercus's Avatar
Thanks.
Don't know when it was out last. Previous owner said that he tended to use the dinette for sleeping more than the PH, so it's not like it has been on there for many years.
So it just slides on and off?
Old 05-28-2014, 12:03 PM   #4
twogone's Avatar
can you post a pic, you may have some type other than SMB install
'95 SMB E350 Quigley 7.3
http://www.taylorarts.com
Old 05-28-2014, 07:08 PM   #5
I have the same issue at times with mine. The steel pole gets stuck in the aluminum housing. To get it out I hold the top section and wiggle it back and forth in all directions while pulling up. It eventually should release.
The housing and post are tapered so if you ram it home it can get stuck. Am thinking of using bar soap as a lubricant but have not tried it yet.
86Scotty has a good suggestion.
"A straight line may be the shortest distance between two points but it is by no means the most interesting". Jon Pertwee as Dr. Who, The Time Warrior.
Old 05-29-2014, 09:01 PM   #6
Quercus's Avatar
The dinette, for reference...
Old 05-29-2014, 11:02 PM   #7
My pole does not have the tabs on it.
Old 05-30-2014, 09:44 AM   #8
twogone's Avatar
that is not the same as my van had ('95)... no help here
Old 05-30-2014, 11:10 AM   #9
Quercus's Avatar
Thanks, gentlemen. Looks like I should probably take the base out, replace the screws, figure out how it works, and reinstall.
Old 05-30-2014, 11:14 AM   #10
looks to me like you have to twist then pull up. I would suspect that the tabs lock down the post.
2004 E350 EB V10 E/PH 2WD
Beatrice
Drizzt
Big Grey
allenl
