Old 07-15-2017, 12:22 PM   #1
Glider's Avatar
Replacement Laminate for White/Light Grey Interior?
I am doing a few mods to my interior, which is built from the standard SMB particle board topped with a white or light grey laminate.
Nancy at SMB North, who has been extremely helpful to me at every turn, has offered to cut new parts for me out of their stock, and ship them to me.
However, I would much prefer to cut my own parts from plywood, and glue on a laminate surface, if I can find a laminate that will match.
What laminates have other folks found that match?
Thanks!
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 07-17-2017, 04:21 PM   #2
Glider's Avatar
I'm going to bump this out of desperation. Does anybody have any sources for a matching laminate material? C'mon...somebody out there has dealt with this...
Thanks.
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 07-17-2017, 08:29 PM   #3
Flux's Avatar
SMB uses prelaminated boards they order the truckload. Head to any specialty plywood store or countertop store and look for their sample chips. Typically Wilsonart or Formica and a couple others. White should be simple to match, the grey a little harder.
<br>
Old 07-17-2017, 08:46 PM   #4
Glider's Avatar
Thank you, Flux. I'll give it a try.
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 07-18-2017, 07:34 PM   #5
Nick's Avatar
I found a perfect match in the Formica family of laminates, mine it's beige but they have lots of gray. Just take a sample with you.
Nick is offline   Reply With Quote
Old 07-19-2017, 12:06 PM   #6
achop's Avatar
Thanks!
Glider, have you decided what type and thickness plywood you're going to use?
I'm considering replacing the drop-down doors on my side door panels with something thinner and lighter than stock SMB particle board. (The weight is causing a problem on one drop-down with a not-quite-adequate snap close and easily warped hinges, ... the big thick panels just seem unnecessary, unwieldy, inelegant ;-) But it's difficult to sand the edges of typical grade plywood to a truly "finished" edge.
- anne
Muy Bonita - 2000 Ford E-350 V10 Quigley with 285/75 R16s, SMB-West RB50, manual PH
achop is offline   Reply With Quote
