Old 10-12-2017, 02:55 PM   #11
Just in case anyone ever needs this...the part numbers for the missing latch in my picture, which goes on the right hand side when facing the side door cabinet, are K4-2714-07 and K4-2338-07. They are made by Southco.
RingTheAlarm is offline   Reply With Quote
Old 10-13-2017, 09:57 AM   #12
Originally Posted by RingTheAlarm View Post
Thanks for the links...it looks like the SMB hinge is offset from the door. Will the ones in your links work with the offset...meaning will it allow the cabinet to sit flush against the door like it does straight from the factory?
It's really hard to tell exactly which hinge you have, but there are probably 100 different types of lift off hinges, so you will just have to look at the specs for the ones you think might fit, then do some measuring. If you can't find exactly the one you are looking for, you might just need to replace both sides. Most likely a new hinge will cover at least a couple of the existing holes, and re-use one at a minimum. Good luck.
www.arctictraveller.com
Old 10-13-2017, 12:50 PM   #13
Thanks! I finally got some more info from SMB. Seems these hinges were fabricated in-house. Looks like I will have to go the route you described.
Serenity
Makalu1
DADDOZR
REDOVAL
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
