SMB water system pressure?
Had a 1.5-2 inch section of 'blue' external water line develop a crack last month.
I had taken the van up to Mammoth Lakes and had forgotten to totally drain the water tanks/lines ahead of the trip. Temps were well below freezing so my assumption was that this oversight is what caused the crack.
I tried a home fix by grinding off the copper clamps from SMB and swapping in another piece of fresh 'blue' water line I had lying around. I secured the new section of hose in place with some standard circle clamps from the hardware store. Filled up the water tank and gave the lines a test. Despite tightening the circle clamps as tightly as possible, there was a lot of water coming out of the hose at the joint beneath the clamps.
This came as a big surprise and made me wonder what the internal PSI is on the SMB water system. Anyone know the stats?
Since my home fix failed, I'll need to have SMB build me a new section of water line that uses their standard high pressure copper clamps. No big deal, but a bit more time consuming and complex.
R
2006 SMB 4x4, EB-51, 6.0psd
