Originally Posted by gregmckay
Kzemach,
How did your work with Second Skin go?
It went fine. I didn't get it under all the carpet, as I was having a hard time pulling carpet up, and decided not to uninstall the seats. Instead, I put it UNDER the van on the outside, plus along side the sides and top area of the engine compartment when the doghouse is removed (i.e. not on the doghouse itself as I recall), on one door, under the floor mat area, on the sidewalls of the engine compartment from the inside of the van, etc.
It's all stuck fine, and I notice some thermal differences, but not really any discernable noise change. Note: prior to this I'd done 1" of foam on the inside of the doghouse, and that made significant noise difference.
Summary: I had absolutely no problems at all with Second Skin, cannot compare to Dynamat, cannot say it made any big noise difference and probably some thermal difference.
