You would need to cap the rear refrigerant lines as close to the Tee under the hood as possible. This also requires first a vacuum evacuation, and refilling with correct amount of oil and refrigerant for a non-rear AC setup. The oil is apparently critical, as Ford has some TSBs about adjusting the oil level in the AC system to prevent compressor damage.
