swivel seat
Thanks for mentioning the wires for the seat belt pre-tensioner Phil and Chris, I forgot about that in my last post. If the wires are damaged, the airbag warning light comes on, and as mentioned, the system will not function properly.
There is a wire loom retaining clip on the wire harness that presses into the bottom, forward area, of the seat frame. If you pull this retainer clip out if the seat frame, you can then route the wire harness to the rear of the seat as mentioned. There is plenty of length without having to splice more wire into the harness. You still need to be careful when swiveling the seat to prevent any damage to the wires.
It's good to know that you can purchase the bases from another source, I wonder if they are still made by Kustom Fit.
John K.
