Old 12-30-2015, 12:33 PM   #1
illking's Avatar
Send a message via AIM to illking
vapor barrier
My window lift mechanism failed so i replaced it. I tried to carefully peel back the vapor barrier but it was glued on very well and i ripped it, its now unusable. Anyone know where to get a new one or what to use in place of the OEM?
www.thevanpires.com
2001 E250 RB30 Agile 4x4
1976 G30 Pathfinder 4x4 SOLD
illking is offline   Reply With Quote
Old 12-30-2015, 04:08 PM   #2
larrie's Avatar
I had to replace my drivers side earlier this year. I also ripped the VB. Replaced it with some left over DynaMat that I got from a forum member. It is doing double duty, sound deadening and VB. You can buy door kits on line, http://www.amazon.com/s/ref=nb_sb_ss...namat+door+kit
Larrie
Old 12-30-2015, 09:02 PM   #3
Why not just use some Tuck Tape to repair the ripped OEM one?
ert01 is offline   Reply With Quote
Old 12-30-2015, 09:49 PM   #4
Pntyrmvr's Avatar
Hi,
Any heavy plastic will do: 6 mil works for houses. I think contractor garbage bags are 5 mil.
Regards,
Gavin
Old 12-31-2015, 04:29 AM   #5
Originally Posted by Pntyrmvr View Post
Hi,
Regards,
Gavin
Totally---and they can be split apart for double their size AND useful for actually putting garbage in them too.
Old 12-31-2015, 04:17 PM   #6
illking's Avatar
Would 3.5 mil do the trick? Just found a leftover roll of plastic sheeting in my garage?
www.thevanpires.com
Old 12-31-2015, 06:42 PM   #7
Anything will help, just the thicker the better.
Old 01-02-2016, 08:02 PM   #8
Pntyrmvr's Avatar
Nothing wrong with two layers tightly sandwiched behind the door panel.
Van22
Van22
PolarVan
PolarVan
