Old 11-26-2014, 10:25 AM   #21
rallypanam's Avatar
Re: Aluminum Underfloor Storage Box $300 (15.5"x15.5"x32")
Finally installed mine!
Thanks Sam!
Old 04-14-2015, 06:23 PM   #22
I finally installed my box I bought from Sam. I went with the dimensions 15"x15"x32" because I felt 15 1/2" was going to be a little to tight. Once I got it, I am glad I did because I do not think it would fit without some major work. Here is the box Sam built.
I remove the spare tire bracket and did some serious grinding to open up the space for the box
Then I cut the opening in the van floor for the top....measured probably 5 times before I cut! Box slid in like I knew what I was doing.
Got everything buttoned back up, just need to figure out what type of handle I want to use.
I really like the finished product. Sam builds awesome boxes and he was great to work with.
Thanks Sam
GBreezy is offline   Reply With Quote
Old 09-11-2015, 06:00 PM   #23
BrianBlair's Avatar
Are you still making boxes/taking orders? I'd still like to get in on this.
BB
BrianBlair is offline   Reply With Quote
Old 09-11-2015, 06:28 PM   #24
How are these boxes supported? They look super clean from inside and below and I'm not really envisioning how the box itself is secured in place.
ert01 is offline   Reply With Quote
Old 09-12-2015, 01:34 PM   #25
northleftcoast's Avatar
BB
Hi Brian,
I'm still making the boxes. Please PM or email me for details on your order.
Sam Mulder
2003 Ford E350 PSD, EB Cargo, Quadvan 4x4
northleftcoast is offline   Reply With Quote
Old 09-12-2015, 01:45 PM   #26
viewtopic.php?f=13&t=6757&start=30
My original post on DIY underfloor storage box has a good thread (page 3 I think) that has several pictures of the install process from my original box.
Let me know if you have further questions. Basically it's four bolts through the floor of the van and through the top of the box at the corners.
Cheers,
Sam Mulder
Old 04-09-2016, 11:12 AM   #27
PM sent. I'm in need of a box.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 04-24-2016, 09:44 AM   #28
I am interested in having a box made for my E350 EB and I live in Oregon. Cold we set up a time to go over the details?
Thanks
gbayless is offline   Reply With Quote
Old 04-28-2016, 03:18 PM   #29
Underfloor Box Price Update April 2016
Not much change here at this time except for bung is now a $20 option.
$300 Standard sized box for EB or RB vans: (15.5" x 15.5" x 32")
$400 XL sized box for RB vans ONLY (15.5" x 24" x 32")
* Boxes are made out of 5052, .125" sheetmetal. All corners either bent or tig welded. Standard size cut opening is 12" x 24" with a 1" flange for carpeted surfaces.
* Access hole rimmed in black vinyl trim.
* Box top flange of 6061, 1/8" bar stock of your choice of height (1", 1.25", 1.5") based on your flooring+subfloor dimension needs (no charge).
* 4 - 2 x 2 x 7/16" spacers for mounting (6061 barstock tacked together).
* 4 - 2 x 2 x 3/16 "washers" (6061 bar stock cut to length).
Options:
$150 Lid/hatch with interior 6061 1" angle flange and aluminum piano hinge.
$20 Aluminum bung with tapped 1/4" npt hole and plug for drainage on an outside corner or bottom where you determine.
$25 Subtract depth to make shallower (you choose any final depth dimension).
$50 Cutaway lower trailing edge for better departure angle (your choice of angle).
Mulder.sam@gmail.com
503 801 0378 __________________
2003 Ford E350 7.3 PSD, EB Cargo, Quadvan 4x4
Old 07-08-2016, 12:08 PM   #30
Underfloor Box Price Update July 2016
After some analysis of actual time and material expenses, please note the adjusted pricing for boxes below:
$375 Standard sized box for EB or RB vans: (15.5" x 15.5" x 32")
$475 XL sized box for RB vans ONLY (15.5" x 24" x 32")
Options:
$175 Lid/hatch with interior 6061 1" angle flange and aluminum piano hinge.
