04-20-2016, 01:31 PM
#31
Is it to late to order a set for a 1998 ford e350 sportsmobile van?
Thanks,Ken
P.S. I also emailed you
04-20-2016, 01:36 PM
#32
Hi Ken, makes you # 12 out of 15 spots on the list. I will PM you later today. Thanks!
04-22-2016, 06:57 AM
#33
Z bracket payment
Originally Posted by ksquared
Thanks for adding me onto the order. Waiting for payment instructions.
Haven't seen any info on payment/billing for the z brackets as of yet. Just checking on when, how and where to pay. Also when they will be in and shipped.
Thanks again
Keith
04-22-2016, 07:53 AM
#34
Thanks again
Keith
Hi Keith, please check for a PM I just sent. I sent one on 4/17 to both you and alta825, but looks like I messed up on the addresses by separating with a comma instead of a semicolon.
Thanks! Ray
04-22-2016, 10:41 AM
#35
Hi Ray,
Am I correct that you only have spots left for people who want a Fiamma mount?
I might be interested in an ARB mount if you aren't interested in the following:
Wondering if you are interested in something like this: The Bunduawn has a flat aluminum stock which is 10" tall that I just need a flat mounting plates to bolt it too - they need to be tall enough to get the bottom of the awning plate about 2 inches above the gutter. 3-4 mounts would be ideal for the 9'6" model.
Thanks,
Adam
04-22-2016, 09:01 PM
#36
Originally Posted by FarmerFrederico
Hi Ray,
Thanks,
Adam
Hi Adam,
I have one more of the ARB/CVT two bracket sets left. Gonejpn2 is in line for that one. I am waiting to hear from him. If he passes, you would be next in line.
You are correct in that I am not making the ARB/CVT sets anymore. The cost was nearly the same as the three pc set (low volume vs setup cost) and the 3 pc set can be used for the ARB/CVT by using just two of the three brackets.
The Bundawn FoxWing is a very cool awning. I have seen them online but never in person. The three bracket set would likely work with that awning with some slight modifications. Perhaps a spacer towards the bottom to level out the upper bend for the back of the Fiamma. I would want to know how much the Bundawn weighs and also the leverage force that might be exerted on the gutter since it has no/optional legs.
Let me know what you think.
Thanks!
04-23-2016, 06:53 AM
#37
Hi Ray,
Put me down for the 3pc set then. The larger, longer Bunduawn weighs 55lbs. I can't find a weight for the ARB 2500.
I'll get the brackets and make a decision with the help of a local friend...it may be that the Bunduawn is too heavy for gutter mount - which is a required mounting location because I'll eventually get a pop-top.
Who knows...maybe I'll get a Fiama???
Please put me down for one of the 3pc sets!
Thanks,
Adam
04-23-2016, 07:54 AM
#38
And just to be clear - when people are running a Fiamma, they are choosing the F35 Pro, correct? If I went Fiamma I'd probably go with their F35 Pro 3.0 9'10" awning. Thanks!
04-23-2016, 08:13 AM
#39
Almost all are running the F45S 3.0 meter/10ft.
An alternative for you would be Colorado Carefree which is looks to be a Fiamma license/copy.
04-23-2016, 12:40 PM
#40
OK - that put things in better perspective... the F45S 3.0 weighs 51lbs.
Please put me down for the 3pc set!
