09-28-2015, 08:31 PM
#51
Re: Econoline Swivel Seat Bases - Who wants them??
Thanks for spearheading this for us Ray. Look forward to seeing you next Sunday at Scott's.
The Zombie Van will be on display. You're more than welcome to conduct an install workshop on it for the group! You know, because I'm all about the greater good.
__________________________________________________ ______
2003 E350 15-Pass Zombie Van • 7.3L Diesel • Quigley 4WD • CCV Mid-Pro Pop-Top • Urban-Coated Gray • Fiamma Awning • Aluminess Nerf Bars • Wind Deflectors
09-30-2015, 12:54 PM
#52
I'm down for that pass side you ordered,2005 quad van,really want the drivers side,that pic you guys had doesn't look like it clears,if it a matter of cutting down shifter,threading it and putting on and off ill do that,
10-01-2015, 11:54 AM
#53
I'm assuming passenger's rotates 180* and Driver's only 90*?
10-01-2015, 04:13 PM
#54
I have the electrical box under my driver seat. Will these clear that?
2023 Transit AWD w/ Van Haus build.
73 BMW 2002 O=00=O
10-01-2015, 05:53 PM
#55
Passenger rotates 180.
Driver can rotate 180 as well, just will not recline seat back more than about driving position, and it requires a little bit of jockeying. 2WD is fine. 4x4 w manual transfer case shifter can be problematic.
10-01-2015, 05:55 PM
#56
The driver side swivel has a raised base to clear the box.
10-02-2015, 08:03 AM
#57
That's good news. I've been on vacation. If it's not too late I would like a driver side base.
73 BMW 2002 O=00=O
10-02-2015, 12:37 PM
#58
So, this little tidbit just arrived - After our order, the manufacturer is only building to order and will no longer be stocking Ford Econoline swivel seat bases. Minimum Order will be five. I am not going into the seat base business.
I am adding all the stragglers to the order I placed. THIS IS ABSOLUTELY LAST CALL FOR BASES, TODAY and that is not guaranteed I can make that happen.
RandallDee - please call or pm me ASAP!
10-02-2015, 12:59 PM
#59
really appreciate all your effort on this ray. thank you very much
10-02-2015, 01:17 PM
#60
Just sent PM requesting passenger side swivel base for my 2014 E350 Quigley in Seattle.
Lyall
