Scott - Ready to pull the trigger on a set of your Rear brake lights but need some info...I'm trying to make a decision between the Ruby Red & Bermuda Black. Leaning towards the black but have some concern the brightness output of the LED's is toned down because of the darker housing, Have you found this to be the case?
Also, you mentioned upgrading the back-up light which you also offer. Those LED's apparently put out about 400 lumen, but I can find the bulb size listed anywhere (tried a couple search's). I'm inquiring because I would like the strongest possible and came across these claiming 1200 lumen for each bulb...a dramatic difference.
https://www.amazon.com/JDM-ASTAR-Ext...SXD7G1HANSBRS4
Would these work in that housing? Any reason you see in which these shouldn't be used?
As always, appreciate your thoughts & advise.
