Hi All, I have responded to the PM's and inquiries here. If you did not receive a PM, please ping me with your zip code and what you want and I will get the shipping quotes out to you. Shipping is targeted for April 7 or so, for this upcoming batch.
Pricing is $195 for the Passenger, $205 for the Driver. Shipping is added. Please get your payment in as soon as possible.
These will work with the stock Ford seats. These units replace the entire stock pedestals. If you have power seat bases, these will not work with the power seat bases. I think if you want to get rid of the power seat base then these should work so the seat itself mounts to the bases.. (We can explore this further, if anyone is interested).
These will work with nearly any 4x4 conversions and clear the transfer case floor shifter. If you have a question about your specific floor mount shifter, then let's discuss to see if it will work.
Installation: These are pretty easy to install. Tools needed: TORX-55, 15 mm and 18 mm wrenches, a sharp knife / box cutter, and needle nose pliers to mod the wire. Cargo vans with rubber flooring is super easy, passenger vans with factory carpet - it is best to trim away some of the carpet and certainly the padding and insulation under the carpet. If you want some help or want me to do the install and are in the SoCal or SF Bay Area, we can discuss your situation.
